Установка VIDA Dice
Re: Установка VIDA Dice
Сообщение solova64 » 18.01.2016, 23:13
dwd писал(а):u mena 3 raznõe windõ. i vse vida not ok. a windu nado obnavlas do SP1
Да.
Инструкция внутри диска по установки.
Где я сылку давал на Vida 2012.
Сообщение dwd » 20.01.2016, 22:18
vsoravno VIDA NOT OK
21:04:17 Installation of VIDA, version 2014D
21:04:17 [INFO] Checking installed applications
21:04:17 [INFO] installed
21:04:17 [INFO] NVIDIA Stereoscopic 3D Driver 7.17.12.6514 installed
21:04:17 [INFO] UltraISO Premium V9.62 9.6.2.3059 installed 20151019
21:04:17 [INFO] Qualcomm Atheros WiFi Driver Installation 3.0 installed 20160120
21:04:17 [INFO] Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 9.0.30729 installed 20160120
21:04:17 [INFO] Intel(R) Processor Graphics 10.18.10.4276 installed 20160120
21:04:17 [INFO] Oracle VM VirtualBox Guest Additions 5.0.0 5.0.0.0 installed 20160120
21:04:17 [INFO] Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 9.0.30729 installed 20160120
21:04:17 [INFO] NVIDIA ??????? 3D Vision 353.84 353.84 installed 20160120
21:04:17 [INFO] ?????? ?????????? NVIDIA 353.84 353.84 installed 20160120
21:04:17 [INFO] NVIDIA ??????????? ??????? 353.84 353.84 installed 20160120
21:04:17 [INFO] NVIDIA Optimus Update 10.4.0 10.4.0 installed 20160120
21:04:17 [INFO] ?????????? NVIDIA 10.4.0 10.4.0 installed 20160120
21:04:17 [INFO] NVIDIA Install Application 2.1002.175.1474 installed 20160120
21:04:17 [INFO] NVIDIA Update Core 10.4.0 installed 20160120
21:04:17 [INFO] IExplorer path = C:\Program Files (x86)\Internet Explorer;
21:04:27 [INFO] Before SetVidaLanguage
21:04:32 [INFO] VIDA_LANGUAGE set to ru-RU
21:04:32 [INFO] ************************************************************************
21:04:32 [INFO] **************************Start computer check**************************
21:04:33 [INFO] Disk C has 190GB of free disk space and is OK to install to
21:04:33 [INFO] Disk E has 797GB of free disk space and is OK to install to
21:04:33 [INFO] Usabledisks = CE
21:04:34 [INFO] Internal memory (RAM) is OK! Total Memory = 8077MB
21:04:35 [INFO] Processor architecture = x64
21:04:35 [INFO] Operating system Windows 7 Service Pack 1 Edition: Professional
21:04:36 [INFO] Installed version of Internet Explorer = 9.0.8112.16421
21:04:38 [INFO] **************************End computer check****************************
21:04:38 [INFO] ************************************************************************
21:04:46 [INFO] Installing Framework35 with cmdLine = /quiet /lang:ENU /norestartrequest.x64=true;
21:04:58 [INFO] Framework35 completed. Result = 0
21:04:58 [INFO] Framework35 OK
21:04:58 [INFO] Security OK
21:04:58 [INFO] Installing VIDA with cmdLine = /zREINSTALL /clone_waitrequest.x64=true;
21:05:04 Installation of VIDA, version 1.00.0015
21:05:04 [INFO] Fetching release from C:\Users\dima\Desktop\VOLVO VIDA 2014D\VOLVO VIDA 2014D\VOLVO VIDA 2014D\install\dvd\vida_dvdheader\CompInfo.ini
21:05:04 [INFO] Result = 0
21:05:04 [INFO] Release = VIDA2014D
21:05:04 [INFO] Prev Release = VIDA2014C
21:05:04 [INFO] Language = ru-RU
21:05:04 [INFO] Quering VIDA database AccessServer for current version/language
21:05:04 [INFO] C:\Users\dima\Desktop\VOLVO VIDA 2014D\VOLVO VIDA 2014D\VOLVO VIDA 2014D\install\dvd\vida_dvdheader\CompInfo.ini
21:05:04 [INFO] User = ***
21:05:04 [INFO] Password = GunnarS3g3
21:05:04 [INFO] No VIDA database found
21:05:04 [INFO] No languages currently installed
21:05:04 [INFO] MULTILANGUAGE set to FALSE
21:05:04 [INFO] In function DecideInstallType...
21:05:04 [INFO] Variable RELEASE = 'VIDA2014D'
21:05:04 [INFO] Variable svCurVer = ''
21:05:04 [INFO] Install type = Initial
21:05:04 [INFO] Installed Release =
21:05:04 [INFO] In function VidaInstall...
21:05:04 [INFO] VidaInstall
21:05:04 [INFO] RELEASE = VIDA2014D
21:05:04 [INFO] Program Menu Folder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
21:05:04 [INFO] Desktop Folder = C:\Users\Public\Desktop\
21:05:04 [INFO] ALBA_INSTALL_XML = vida.install.xml
21:05:04 [INFO] Alba is starting installing VIDA using = vida.install.xml
21:05:04 [INFO] Input params to Alba = request.dice=true;request.sqlexpress=true;request.adobereader=true;request.isoview=true;is.vow=false;request.x64=true;
21:06:49 [INFO] Alba has finished installing VIDA
21:06:49 [INFO] Setting uninstall icon
21:06:49 [INFO] End of installscript
21:06:54 [INFO] VIDA completed. Result = -1
21:06:54 [INFO] VIDA NOT OK
21:06:54 [INFO] Check if DiCE is installed
21:06:54 [INFO] DiCE installed. Setting Path to VIDA log
21:06:54 [INFO] DiCE log location = C:\VIDA\System\Log\Diagnostics\TSDice32.log
21:06:54 [INFO] Result = 0
21:06:54 [INFO] Setting DiCE log level
21:06:54 [WARNING] Could not find Log level for Diagnostic. Setting log level for DiCE to DEBUG
21:06:54 [INFO] DiCE log level = 2
21:06:54 [INFO] Setting file security for DiCE
21:06:54 [INFO] VIDA installation ended
[/spoiler]
dwd
Сообщение stark » 20.01.2016, 22:29
Из лога я понял, что ставите не на 'C'
Сообщение dwd » 20.01.2016, 22:59
na C.u mena drugovo netu.
dwd
Сообщение mitja » 20.01.2016, 23:02
на рабочем компе осталась утилитка которая проверяет на совместимость компа с VIDA, завтра скину, либо сам гугли - ViDA compatibility tool
Сообщение stark » 20.01.2016, 23:13
dwd писал(а):na C.u mena drugovo netu.
C:\VIDA
Сообщение nightracer » 21.01.2016, 02:00
2014 Vida на с ставиться категорически отказалась. Пришлось делать виртуалку и добавлять к ней еще один диск.
nightracer
Сообщение mitja » 21.01.2016, 10:49
Сообщение vladdd8 » 21.01.2016, 19:12
Цитаты с раздачи с Рутрекера
" Проверь NF , если есть 4,5 убирай его , все его папки и корни ."
"Попробуй Яву поставить и NF4.0-NF4.5 без NF4.5-1."
"если после запуска, в "Коммуникационный инструмент" — крест или другой болт, надо запустить рег.файлы из \VIDA2014D\Install\Utils которые на образе/диске с VIDA - vida.reg и EnableIEHostingx86.reg (или EnableIEHostingx64.reg для x64)."
vladdd8
Трансмиссия: AW55
Клубная атрибутика: magjuibe
Login in CityGuide: magjuibe
Баллы репутации: 34
Сообщение dwd » 22.01.2016, 00:45
takoi java netu
http://www.oracle.com/technetwork/java/ ... 38363.html
vladdd8 писал(а):Цитаты с раздачи с Рутрекера
dwd
